ih 37 baler
   / ih 37 baler #1
amberwave
wapak ohio
ih 37 baler
I have a problem with the plunger, or pitman arm not being correct. The stroke is to short on pitman arm and plunger bottoms out. I need to know a measurement of pitman arm to see what is wrong. I know nothing about this baler aquired as is and previous owner gone. Any help i can get to fix problem would be grateful.
   / ih 37 baler #2
I dont know how the stroke can be too short, since it is a constant controlled by the throw of the crankshaft driving the pitman arm. ... Do you mean the plunger is hitting a stop in the chamber preventing a full stroke of the plunger? There is a shearpin behind the flywheel that will shear off when this happens. The stop is a safety device, which if triggered must be reset to resume normal operation.
   / ih 37 baler
plunger hits the front of baler {fly wheel }. I think someone has repaired it with the wrong part just not sure if its the plunger or pitman arm . if i pull center bolt out of pitman arm i can spin baler over and when plunger bottoms out pitman arm spreads 2.25 inches apart .
   / ih 37 baler #5
The pitman on my I37 is 38" center to center.
2014 Club Car Electric Golf Cart (A51694)
2014 Club Car...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
