IH 3616 hydraulic problem
/ IH 3616 hydraulic problem #1
Skifly05
Cloquet, MN
International 3616
Have a IH 3616 with 3141 Backhoe out of 1960's(?). The backhoe hydraulics lock up and bog the engine in various positions. Hoe lifts but bogs on push down, outriggers bog in both directions. Loader lifts but bogs on curl. Hydraulic fluids at correct levels, seems there is something flatly blocking flow in various movements. Any ideas?
/ IH 3616 hydraulic problem #2
That is easy enough to check.
Remove the hose from each cyl and place in bucket, and move the lever for the spool that controls that cyl, and see if the valve is working correctly.
Have you checked any pressures?
Could there be any trash in you BH valve.
Are the hydraulics on the tractor working correctly?
Check them QD's for proper operation.
Hydraulics:
Type: -unknown-
Capacity: 20 gal [75.7 L]
Pressure: -unknown-
Valves: 2
Total flow: 36 gpm [136.3 lpm] (total)
39 gpm [147.6 lpm] (total, optional)
19 gpm [71.9 lpm] (front pump)
22 gpm [83.3 lpm] (front pump, optional)
10 gpm [37.9 lpm] (transmission pump)
Steering flow: 7 gpm [26.5 lpm]
Steering press.: 2200 psi [151.7 bar]
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
ATTENTION! PLEASE READ (A64126)
ATTENTION! PLEASE...
