IH 3414 Did it come with PTO?
   / IH 3414 Did it come with PTO? #1
pddtovar
CA
IH 3414
I just bought a IH 3414. The PTO has a cover bolted over it. It looks factory. Did this model come with PTO? If not, can it be converted?
   / IH 3414 Did it come with PTO? #2
It probably did not come with a PTO. It is easy enough to add if you can find the parts.The parts should be fairly easy to get off of one of the farm "cousins" to the model. You could probably get a better answer f you asked on the Red Power forums. many knowlegable people over that way. They can tell you what you need.
   / IH 3414 Did it come with PTO? #3
Chances are you would need to start at the clutch for a drive and add the shafts thru the transmission and differential.
   / IH 3414 Did it come with PTO? #4
My 3414 has a pto which was obviously an add on from an ag tractor, as it was painted red instead of the typical IH industrial yellow. It is not a 'live' unit, however, as the 3414 has only a single stage clutch.
2015 GMC 3500 HD 4x4 Crew Cab Pickup truck (A55973)
2015 GMC 3500 HD...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2018 Ford F-350 (A55973)
2018 Ford F-350...
