IH 2444 brake rebuild
   / IH 2444 brake rebuild #1
jezorek
Bronze Member
NJ
Ford 1910 w/1710 FEL
I've almost completed a brake rebuild on my !H2444. All of the linkages on the left side were rusted away. They are fairly easy to fabricate. The right side casting was full of grease/oil. At first I thought it was due to a leaky seal but upon inspection I don't see any leakage. It is a mystery where the grease or oil came from. Any one have a guess?
The only thing I have left to do is to connect the pedal return springs.For the life of me, I can't remember where they were connected. Can any one help with an explaination or picture?
   / IH 2444 brake rebuild #2
Here is a picture of the brake assembly. For some reason I'm thinking the spring attaches to a notched out spot in the footboard.
Is your differential the hydraulic reservoir..?? I have a 240, and had a 2404 for a short while. The 240's reservoir is rather small,and up on the torque tube, I kinda' forget about the 2404...
If your fluid level is up in the differential, then I don't have a clue. I do know, when the seals were bad on the bull pinion shaft on my Super C, the inboard bull pinion shaft bearing was shot, and I replaced it. That has been over 16 years ago, and still nice and dry.
   / IH 2444 brake rebuild #3
hydraulic oil can leak from the o-rings in the hydraulic cover and settle in the brakes. Look for traces of leaks above the brakes.
DJ54- Your memory has proven to be correct. The springs attach to the rear of the foot plate.
Thanks,
Leigh
   / IH 2444 brake rebuild #5
Now if I could just remember where I sat my coffee cup 5 minutes ago. :confused:
   / IH 2444 brake rebuild #6
I had a IH 424 and it was a very similar tractor and had brakes like this. The brakes are a problem if the tractor sits outside water seeps in around the cast cover and lets it all rust up. I thought about sealing the cover with silicone at least the upper portion to seal out any water that may migrate in during a rain.
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
12in Backhoe Bucket (A52748)
12in Backhoe...
Toro Workman 3200 Cart (AS IS) (A50774)
Toro Workman 3200...
KJ U-Type Shackles (A50121)
KJ U-Type Shackles...
Utility Trailer (A50515)
Utility Trailer...
