IH 1066 tractor problem - white smoke, clicking, loss of power
   / IH 1066 tractor problem - white smoke, clicking, loss of power #1
kkjpmc
Sanford, CO
IH 1066
Hi,
Was disking and tractor lost power, clicking sound was heard from engine and white smoke came out from beneath tractor. Have I blown the engine ? How bad is this? Was running tractor in correct gear. Am relatively new to farming (8 yrs), have 50 acres for oats and alfalfa, and need to get seeds in the ground. Time - and water- are running!
thanks in advance
PMC
Hi - No fuel smell. Smelled like burned oil. Thoughts ?
   / IH 1066 tractor problem - white smoke, clicking, loss of power #4
If the "smoke from beneath tractor", and the smell of burned oil was coming from the breather tube, I'd bet your problem is a piston/sleeve issue. Nothing related to fuel or intake manifold. You most likely have internal problems.
   / IH 1066 tractor problem - white smoke, clicking, loss of power #5
Check intake between turbo and intakemanifold .If there is oil ........Then turbo or and or pistonrings
Thank you DLT, we'll check that. Thank you to everyone who has responded so far! It's all helpful !
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2012 CASE IH 1230 LOT NUMBER 186 (A53084)
2012 CASE IH 1230...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2020 JOHN DEERE CP690 LOT NUMBER 204 (A53084)
2020 JOHN DEERE...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
