Ignition Switch Question About Mitsubishi 2050 FD
   / Ignition Switch Question About Mitsubishi 2050 FD #1
Coachnic
Suwanee, Georgia
Mitsibushi D2050
My key broke off inside my ignition switch. I took the ignition switch off, the broken part of the key fell out, thank goodness, which was good, and wired it back up (not easy to do this because the dash board will not fully come off because of the throttle lever. I thought I was connecting the correct wires to the correct poles on ignition switch. It fired up but, the yellow charge light lit up and stayed on. I know it's not the battery as I also put a new battery in it with a manufacture date of 2/20. I tried to trace the wires throughout the engine but can't, they are wrapped tight in a black sheath that looks like electrical tape through out the whole wiring harness. Here is what the label on the ignition switch poles and also the color of the wires that are suppose to go to it. Does anyone know which wires match up to which poles.
IGNITION SWITCH POLES
IG
G1 has a plate that connects to G2
G2 has a plate that connects to G1
ST
BAT - I know the correct wire that goes to this
Wire Colors
Red/Black - these wires are together with one connector
Yellow
Blue
Black with White Line in middle of black - I think these are the Glow Plugs
Black - This is the battery wire I am sure of
   / Ignition Switch Question About Mitsubishi 2050 FD #2
I sold my Mitsubishi a few days ago and the manual along with it. For help I'd go to Valley Power. They're a Mitsubishi / Satoh dealer from "way back". They have manuals for models which were never imported. Valley Power I did find a wiring diagram on my hard disc but my terminal identifiers are not the same as yours.
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2011 SHOP MADE UT (A53843)
2011 SHOP MADE UT...
20X30 ALL-STEEL CARPORT W/ ENCLOSED SIDEWALLS (A53843)
20X30 ALL-STEEL...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2014 MACK CHU DAY CAB (A53843)
2014 MACK CHU DAY...
