Ignition Switch Question About Mitsubishi 2050 FD
   / Ignition Switch Question About Mitsubishi 2050 FD #1
Coachnic
Suwanee, Georgia
Mitsibushi D2050
My key broke off inside my ignition switch. I took the ignition switch off, the broken part of the key fell out, thank goodness, which was good, and wired it back up (not easy to do this because the dash board will not fully come off because of the throttle lever. I thought I was connecting the correct wires to the correct poles on ignition switch. It fired up but, the yellow charge light lit up and stayed on. I know it's not the battery as I also put a new battery in it with a manufacture date of 2/20. I tried to trace the wires throughout the engine but can't, they are wrapped tight in a black sheath that looks like electrical tape through out the whole wiring harness. Here is what the label on the ignition switch poles and also the color of the wires that are suppose to go to it. Does anyone know which wires match up to which poles.
IGNITION SWITCH POLES
IG
G1 has a plate that connects to G2
G2 has a plate that connects to G1
ST
BAT - I know the correct wire that goes to this
Wire Colors
Red/Black - these wires are together with one connector
Yellow
Blue
Black with White Line in middle of black - I think these are the Glow Plugs
Black - This is the battery wire I am sure of
   / Ignition Switch Question About Mitsubishi 2050 FD #2
I sold my Mitsubishi a few days ago and the manual along with it. For help I'd go to Valley Power. They're a Mitsubishi / Satoh dealer from "way back". They have manuals for models which were never imported. Valley Power I did find a wiring diagram on my hard disc but my terminal identifiers are not the same as yours.
Utility Trailer (A52377)
Utility Trailer...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
ROBIN AIR 34788NI A/C RECOVERY MACHINE (A53843)
ROBIN AIR 34788NI...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
