Ignition Problems
/ Ignition Problems #1
Rocky Jones
Ford 600 1955-1958
Hello everybody, I'm Rocky. I have a Ford 600 I bought about 3 years ago. I have had intermittent ignition problems over the years. The tractor will run fine, but once warmed up will quit running. I have bought all new ignition parts except a distributor. It is a 6 volt system. I have power up to the coil, but no spark out of the coil (new coil). I'm looking for information on how the rebuild the portion of the distributor where the power comes in and goes to the points. It looks as though mine was juror rigged sometime ago. Thank you for your time.
/ Ignition Problems #3
Some ignition systems will have a resistor in series with the points on the 6 or 12 volt side. That resistor could be opening when hot.
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
2006 Genie Z45/25J Articulated Boom Lift (A64047)
2006 Genie Z45/25J...
2022 EZ-GO ELITE...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
