Ignition problem
   / Ignition problem #1
Bobandia
Lexington, ky
None
I have a 2005 Branson 4220 and the ignition no longer starts the tractor. I am able to start it with two screw drivers with the key in the on position. I asked about this at the dealer and they just told me that there could be several reasons why it won't start. I have not tried taking it apart yet, but he did mention that there could be three or four safety switches that could cause this as well as a faulty ignition switch. When it was working there was a noise that sounded like a fuel pump, perhaps, that stopped when the plug heater was done. Anyone have a diagram of the start safety switches or at least a description of where to look?
   / Ignition problem #2
The lift pump and glow plugs should work when the key is turned on.
Lift pumps fail regularly and the auto parts stores sell a suitable replacement for around $50.
I would check the key switch with a volt meter or test light first.
For safety switches my 3510 has clutch and shuttle shift switches. They are easy to check.
   / Ignition problem #3
PTO switch also has one on mine.
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
(1) RYOBI 212CC GENERATOR (A51248)
(1) RYOBI 212CC...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
