docrocky
- Joined
- Jul 18, 2011
- Messages
- 207
- Location
- NW Ohio and SE Michigan
- Tractor
- Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
Bought a Craftsman Rototiller that fits onto my Sears 15 few years back at farm consignment auction...realizing that few of us get rid of running equipment...but I am getting more comfortable with small B&S engines.
The first thing I did is test for spark, it turned over reasonably but no spark. I pulled off the recoil starter cover and as usual the magnet portion of the flywheel fairly rusty. Also the ignition coil had been changed by ?previous owner. Removed it without difficulty and did the usual wire brush cleaning of the flywheel and the coil pillars. I checked to see that there was one wire group grounded to the left pillar where the dust fin attaches to the coil and the kill switch wire was insulated. Turned engine over again and no spark. I then used the spark tester by Stens as well as older one used on larger engines which as a small lite bulb like a flashlight bulb. Still no spark via the tester light.
I then removed the spark plug and used the tester lights connected to the coil via sp wire and appropriately grounded it. With usual pull of recoil, get spark lighting the testor lamp but no spark passing thru the Spark plug. Tried two new plugs but still no spark passing, even with the finger feel test. I was very careful to gap the coil with the usual business card thickness but no success. I even tried metal gap setters starting with .020 down to .010 with same effect.
I then bought a new coil via e-bay thinking maybe some weakness in the coil was giving a week spark but not enough for the plug. Same result...great spark via the tester but still no spark. I even took off the flywheel to ensure the key had not slipped. I also remove what was left of the old points and condenser. Now I am not sure if the owner who replaced the coil for a newer version not requiring points and condenser ever got it started.
anybody have an owners manual indicating exactly what spark plug is needed. I assumed the one hooked to the engine was the right one, but who can tell. I currently am trying a champion J8C.
CRAFTSMAN ROTOTILLER
B&S 8hp
model; 190402
type 0780
code 74052210
Tiller
Model917251891 SN 1577
B&S 8hp
model; 190402
type 0780
code 74052210
Tiller
