Ignition coil running very hot
   / Ignition coil running very hot #1
mdross1
Windham
John Deere 70
Was wondering how hot do the ignition coils get while running. I was in the process of putting a timing light on the newly restored 70 had turned on the ignition when the phone rang. By the time I got back to the tractor thought I would to check to make sure the distributor bolts were loose and noticed the coil was so hot could not touch it. Up till then never thought about them running hot at least like that. Anyone ever notice how hot there ignition coils run?
   / Ignition coil running very hot #2
Mine gets hot enough that I don't like leaving my hand on it.
   / Ignition coil running very hot #3
With ignition on and not running, the coil will get very hot if the ignition points are closed. If the points were open, power would not flow through the coil. When engine is running of course, the points are constantly opening and closing so the coil doesn't have constant flow of voltage. You should find that the coil does not get nearly as hot in normal operation with engine running. .
   / Ignition coil running very hot #4
The coil is a 45 watt heater when left energized. It's going to heat up until reaching equilibrium .
So no resister should be needed? I also noticed the 60 coil heats up when running but never left the ignition on without engine running to compare against the 70. What is the resistance supposed to be on these coils at the studs?
   / Ignition coil running very hot #7
So the trick is to not leave the ignition on so the coil doesn't get "very hot". As long as the ignition coil still works after "running hot" then the solution should be easy. ;)
   / Ignition coil running very hot #8
The resistance will vary between different coils. In general it is low. Because of inductance the current doesn't increase instantly when the points are closed but gradually until the magnetic field becomes saturated. When points open the magnetic field collapses generating high voltage pulse in secondary winding connected to the spark plug. The capacitor in ignition has two functions. It limits arcing when points open and together with primary winding makes an oscillator so the coil generates several sparks in fast succession for each points opening.
Since the coil is autotransformer you can measure secondary winding between posts and sparc cable connector. The resistance of secondary is way higher then primary.
Probably over thinking it but knowing these coils are oil filled and laying on their sides has to expose part of the transformer has me wanting to fabricate a bracket to stand the coil up for piece of mind.
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2006 Poly-Coat Tanker Trailer (TITLE) (A50774)
2006 Poly-Coat...
Kubota SVL75-2 (A50120)
Kubota SVL75-2...
2014 Ford Escape SUV (A50324)
2014 Ford Escape...
2004 Mercedes E320 Sedan (A50324)
2004 Mercedes E320...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
