If you see a Pony Grader for sale - Buy It!
   / If you see a Pony Grader for sale - Buy It! #21
While I really would like a land plane or an actual road grader (that would be nice) I've taken to using my field drag to repair the road and drive. It's the perfect width, fills in the low spots even though that creates a soft spot. I have limited traffic on my road and drive though so it's rare I need to do that, on the neighbors portion I'll do that when ever I do mine. What ever is dragged to the end, I bucket back up to the top to fill washouts. While the road is all on private property we still get a road crew once a year, they tend to help and hurt keeping it in good condition as they get lazy and try to narrow the width which can make the 2 turns tough on the trucks when I need big deliveries or hauling something out.
But if I could find one of those old steel wheel graders for a decent price, I'd buy it! Dual purpose, grade the road once a year and useable yard art :)
I have a little DR grader that works just fine but at 4' a swipe it's really only good for trails and tight areas. Reading above... there are definite benefits to being at the end of the road it seems!
   / If you see a Pony Grader for sale - Buy It! #22
I use a box blade with rippers to loosen shoulders then tilt it 15 degrees and roll it back to make it cut. This rolls the material off of the shoulder so I can pull it to the center with a road drag. The secret is a good crown. I have no spots where water stands and as a result my half mile drive is one of the best roads in the county.
   / If you see a Pony Grader for sale - Buy It! #23
Here is one near us FS on FB, they call it a 6ft Pony grader. Googling it, I can not find one like it...
   / If you see a Pony Grader for sale - Buy It! #24
Here is one near us FS on FB, they call it a 6ft Pony grader. Googling it, I can not find one like it...View attachment 1305910
Looks like it's hydraulically adjustable with its own electric pump, like a dump trailer, probably with a remote adjustment to be pulled by a truck?
   / If you see a Pony Grader for sale - Buy It! #25
Yes to all that. Was wondering about the make?
It would be nice to see more pics. What is the price?
It looks like it has a 12V (snowplow) hydraulic pump with a single acting cylinder that pushes that trailing axle up or down to adjust depth of cut. Angle adjusts like a rear blade. I can't see how they adjust tilt. They list the price at $1,500
   / If you see a Pony Grader for sale - Buy It! #30
FB verbiage with my improved photos. Looks like the frame or tung is bent and it just being 6ft wide makes it minimal width.
Hard to find Pony grader, sold as-is. 6’ blade w/new, hardened wear edge on the mow board. 12v hydraulic blade lift system w/battery included. 10’ power cord to easily raise & lower the blade from the cab of your vehicle. Full size tires for over-the-road use. Blade can angle left or right (needs some welding work). For use with 2” ball for easy pickup truck towing. Contact: [hidden information].
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2285 (A58376)
2285 (A58376)
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
JOHN DEERE 333G SKID STEER (A52709)
JOHN DEERE 333G...
JOHN DEERE 469 BALER (A58216)
JOHN DEERE 469...
