If you own a M6040 please reply
   / If you own a M6040 please reply #1
Ryang
I keep jumping around with different tractors and now believe I will end up with a M6040, because I have some big mowing jobs ahead of me. I want to know if the M6040 will have enough power to pull a 15ft flexwing mower. This would be rented 4-6 times a summer and will use a 7ft Bush Hog to do the smaller jobs. I will have a FEL, but would like to take it off while doing those big jobs. I'm a bit worried this will be overkill for my 5 acrer lot, but the calls keep coming in. I will be stepping up from my L3400 that will go to my brother to help out. Please let me know if you have been happy with the new M series tractors.
Ryan
   / If you own a M6040 please reply #2
Don't have a M6040, but do have a M5400 (older version of the improved M6040). I wouldn't do it, that's way too much mower. You could run a 10 footer in ligher stuff or go real slow in heavy stuff.....
Darren
Thanks for your reply. I was thinking the same, but wanted to check.
Ryan
   / If you own a M6040 please reply #4
A M6040 would handle a big bat wing if the land is reasonably flat. It might only take 2 hours give or take to do 5 acres, depending on how tall and dense the grass is. If the grass was 3-4 ft tall and lush, I'm guessing the M6040 would need a lower ground speed.
One of my fields is 7 acres - former orchard, not smooth. I have found a 90" woods finish mower with swing-back blades to be just the right tool. It makes a nice looking field even if only cut 3 or 4 times in a season. 40 shaft hp will drive it fine (although I have 50). There are some obstacles and a few moguls, so it takes 4-5 hours.
   / If you own a M6040 please reply #5
I believe, like an above poster stated, that a M6040 will run a 15ft batwing. I have a M7040 and a heavy duty older Bushog batwing and it runs it with no problem in medium density grass. I have to slow down because of bumps before it looses power. I generally mow in 3rd gear if that gives you a reference. This might be equivelent to 2nd gear in a M6040 for the power to speed ratio in a similar type of grass.
If I were you I would go ahead and get the M7040 (wait......I was you........ and that is what I did........) for a few extra dollars and dont worry about being able to do the given job or not.
I do agree that the M series is too big for 5 acres but like you said you want to mow with a batwing. That was my sole reason for getting the bigger tractor.
I wish you luck in whatever you decide
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
STORAGE FEES (A51222)
2020 KUBOTA RTV...
CATERPILLAR 304E CR EXCAVATOR (A51242)
CATERPILLAR 304E...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
2025 CFG Industrial PD750-PZ Post Driver Skid Steer Attachment (A49462)
2025 CFG...
