If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #371
Same as mine did. It was both drive motors. It worked great after replacing them. ($5500-6000/ouch) still running great 1000hrs later. Never did find any after market replacements. Others might be able to help. They obviously rebuild them b/c bobcat insisted on keeping the old cores. After seeing the inside of the motors and what went wrong, I believe a good tool and die shop could rebuild/make the brass sleeves that go bad.
Again, there are wiser ones than myself here.
   / If you have Toolcat questions, ask them here... #372
is there a way of testing the charge pressure, and today one of my operators told me it worked fine for the first 10 mins and then lost its power again, now i dont know if that would have anything to do with it being colder out or not
   / If you have Toolcat questions, ask them here... #373
Yes you will need the coupler and gauge. Yes temp can influence it. Have you looked at the "weak drive on 5600s"?:confused3:
   / If you have Toolcat questions, ask them here... #374
If all other functions( boom,bucket,steering,bed) are working okay( while not in drive), I believe your charge pressure is fine. Once in drive, the worn areas of the drive motors allow the fluid to bypass the motor easily and all pressure is lost to everything else. As it warms up it gets worse. When my was initially started it would work well for a short time. The colder it was, the longer and better it worked. As the colder hydraulic fluid warms, the fluid viscosity(friction) decrease and passes the worn areas easier. Think of cold syrup through a narrow opening vs warm syrup through same narrow opening.
   / If you have Toolcat questions, ask them here... #375
That is incorrect. Lift,tilt, bed and aux use separate pumps but are pilot/charge pressure operated. A simple charge pressure test on both front and rear systems will tell the tail. Basically what happens is the motors leak so bad that charge pressure dumps destroking your hydrostatic pumps and causing pilot/charge pressure controlled functions to not work or work poorly. :mischievous:
   / If you have Toolcat questions, ask them here... #376
I defer to Jabonee. I meant to reference what would happen with mine regarding all other functions. With regards to the fluid bypassing through the worn motors was as it was explained and shown to me. I agree with you(Jabonee) just wish I could have explained as well as you did.
   / If you have Toolcat questions, ask them here... #377
Is there a way to tell if both drive motors are gone or just one of them
   / If you have Toolcat questions, ask them here... #378
Can someone please tell me on a D model, where the fuse and relay are located for the Air Conditioning compressor?
   / If you have Toolcat questions, ask them here... #379
I have an s300 , it travels with the seat bar up but the pedal functions don't work . Should it travel with the bar up . Thank you
   / If you have Toolcat questions, ask them here... #380
Question should have been posted in Bobcat Construction Equipment Forum not Toolcat. To answer question, yes. If start engine and push the Press to Operate Button with seat bar up the brakes will release to drive and loader functions will remain locked.
2017 FORD E-350 SUPER DUTY 16' BOX TRUCK (A60430)
2017 FORD E-350...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2012 Dixie Chopper Magnum 2460 60in Zero Turn Commercial Mower (A59228)
2012 Dixie Chopper...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
yellow ball Trailer (A56859)
yellow ball...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2014 FREIGHTLINER...
