mike123
Will a 235 85 16 tire fit on the toolcat?
Thanks
Thanks
Thanks
With the "D", you can go into the setup menu (where you can also setup tire size, etc) and enable/disable 2-speed. Perhaps yours is disabled there.
I can give you all the info.
UFM82
The front tires are dragging, like they are locked up. Only does this sometimes.
Most times I can put it in reverse and it will free up. Other times it still drags the front tires in reverse. It is showing no error codes.
One time a few years ago it did the same thing but the rear tires were dragging. It was showing an error code then, for the rear speed sensor. Fixed that with some contact cleaner sprayed on the connector.
Thanks
Chickenman:
Did you get any help with this? I have a 2003 with the same issue. Mine shows no codes, but has in the past triggered the rear sensor once in a while. Seems to only do it when hot, but may just be coincidence. I'd love to hear if you're able to get help with this. My dealer hasn't been able to help me.
BLES
If it was a John Deere product, a guy could get some help.
I have just purchased a d series 2009 toolcat and am unsure of its capabilities on rough terrain. How does it do on hills and getting across stream where banks slope up steeply. Any anectodal information on handling (rollovers or tipping) would be appreciated.my toolcat 5600 has been down for a while with drive problems.As soon as it warms up a little it will barely move . The mechanic and techs diagnosed a faulty pump.First a rebuild and then new.No change and now they want to replace the drive motors.How common is this?The machine has 1000 easy hours on it. thanks richard
