Monster5601
Platinum Member
I have a B3030 with two rear remotes. The issue I have is I cannot make a connection to the second remote quick connects. The quick connects are mounted in a housing that holds the release collar in place so when you push to connect or pull to disconnect the hydraulic line moves while the collar stays fixed allowing the connection. The issue is the hydraulic lines cannot move because they are hitting against the hydraulic lines of the first remote which are above the second set of remotes. The remotes are plumbed as shown by the installation instructions and the dual remote kit is Kubota's.
Anyone with a dual set of remotes that functions correctly, please take a picture of how the hydraulic lines are routed and post.
Bob
Kubota's installation instructions:
http://www.tractorbynet.com/forums/...remote-b7304b7305b7306b7307-remote-valves.pdf
Bob
