If you had $15K in your pocket...
   / If you had $15K in your pocket... #11
A basic gear 2wd Mahindra can be had for that, probably similar size and power to the Long. Are you committed to new from a dealer? 15k could go a long way with newer used, either from a dealer or civilian.
Since you asked what "I" would do, I would lean towards a $6000-8500 dollar used 2wd industrial (yellow ford, yellow massey, or yellow jd) with 45-60 hp.
Edit: I would start creeping the local municipal and equipment auction.
   / If you had $15K in your pocket... #12
Since he said he didn't want to be fixing before use each time, I wouldn't suggest a well used auction tractor.
An individual might have a good used one, but likely want what he owes on it and with 0 down and low interest, likely it is about the same or more than a new tractor. The only advantage of used (1-2 years old) is that you can get them with the lower EPA requirements so not so much BS on the engine to wonk out and especially no DEF to add and wait for regen cycle sometimes like larger tier IV tractors + many of the new diesel require an ECU computer just like our cars which is another $1000+ item to break.
I would look for a 2013 or 2014 hold over (NEW) and get the best financing available and highest HP that I could get. LS makes good tractors and they are cheaper than the other brands and have lots of standard features that other brands charge at least an arm for and some times a leg too boot.
With regard to FEL and 4 WD, if you have never used those, then you really don't know what you are missing. 5 years ago I would have argued that FEL was not needed but I did think that I needed 4WD and am super glad that I got it as it has gotten me out of some muddy situations many times.
You just don't realize how handy a FEL is if you never used one (like me before I bought my first tractor with one). I use it for moving dirt to fill in holes, digging out my dried up ponds, hauling material like wood, sand, rock, timbers etc. cause it sure beats a wheel barrow. MY wheelbarrow hasn't been moved in 5 years except to move it out of my way once to a better storage location.
I wouldn't recommend a FEL without 4WD due to lack of traction when the FEL bucket is loaded.
Lastly, except for PTO related activities, a 4WD with 20 HP will outperform a 30 HP 2 WD tractor due to SOO much better traction.
   / If you had $15K in your pocket... #13
What would I do?
I would look hard at the Kioti DS 4110H and 4510H. Consider the 15,000 a good down payment and finance the rest.
As others have stated not needing/not wanting/not knowing or not being able to justify the loader cost has to be assumed here so with the knowing of how handy a loader is I would opt for the loader on anything I looked at and include it in with the purchase if possible.
   / If you had $15K in your pocket... #14
what I would do is shop used and buy a low hour deere or Kubota definite 4x4 / hydro drive and loader its a whole different type of tractor then you have
   / If you had $15K in your pocket... #15
If I had $15k ... I'd put new tires on my truck!!
   / If you had $15K in your pocket... #17
Kioti
I purchased a tractor just over a month ago. The top 3 I considered were JD, New Holland & Kubota in no order. While looking I ran across some info on a Kioti and the specs really impressed me. Compared to the other 3 in the same HP range it had higher flow in the hydraulics (more gpm), it lifted more and weighed more. All 3 of these are what makes a tractor. Once I saw it and the way it was built I was even more impressed. It has a lot of small features not found on the others. I bought it on the spot.
   / If you had $15K in your pocket... #18
Couldn't imagine having a tractor without a FEL.
Have you thought of all the possibilities of a FEL with a quick attach bucket?
Grapple, pallet forks etc....
I'd see if you can find a leftover Kioti DK40/45 HST with FEL..tier 3, no computer, FWD, standard quick attach bucket, 2765lbs lift capacity, throw your 15 at it for a down..guys were paying 21 to 23 for a new tractor with FEL..heck of a unit.
   / If you had $15K in your pocket... #19
Check out a Kubota MX5100 or MX4700. I would get a loader and 4wd. You'll love it. If you want used look for a grand l 30 or 40 series. Rock solid tractors.
   / If you had $15K in your pocket... #20
If I had $15K in my pocket, I would be wearing someone else's pants! :laughing:
UNUSED RAYTREE RMLL60-60" POWER RAKE LAND LEVELER (A54757)
UNUSED RAYTREE...
UNUSED LANDHONOR LHR-SB2T3M CHAIN LEVER HOIST (A54757)
UNUSED LANDHONOR...
70pc 12ft.x 3ft. Grey Metal Roof Panels (A55758)
70pc 12ft.x 3ft...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2008 AAR MOBILITY SYSTEMS REFRIGERATOR CONTAINER (A54607)
2008 AAR MOBILITY...
2016 Chevrolet Sonic Sedan (A55758)
2016 Chevrolet...
