Buying Advice If you could only choose hydro or cab what option would you choose for your tractor?
   / If you could only choose hydro or cab what option would you choose for your tractor? #21
If you never sat on a tractor I'd opt for a tractor with both. If you have and feel comfortable with manual shifting and all, cab hands down. My 6530 has a cab for all the right reasons but is 24F/R (creep selector doubles the 3x4 speed selector) with F/R shuttle for fast shuttle work. I don't want nor need hydro. My riding lawn mowers are hydros.
   / If you could only choose hydro or cab what option would you choose for your tractor? #22
Well, a gear tractor can do everything a Hydro can do, but its hard to heat an open station, so I'd take the cab if you have to choose. Mind you I have gears and open station which is fine for me where I live.
   / If you could only choose hydro or cab what option would you choose for your tractor? #23
Cab, Really gears are fine, especially a shuttle.
   / If you could only choose hydro or cab what option would you choose for your tractor? #24
Do you work in dusty conditions? Most of the cabs I see are covered in dust. I don't see how the operator can see out the sides and back. I realize you guys with cabs are probably staying on top of things keeping the glass clean but the cabs I've seen look like they've never been cleaned.
As for the HST, I think I'd choose it over a cab. I have lots of limbs to deal with and while I certainly would like to have a cab I don't feel it would work out in my situation.
   / If you could only choose hydro or cab what option would you choose for your tractor? #25
I have never seen a post on here where anybody regretted getting a cab;)
Get any snow this year?
   / If you could only choose hydro or cab what option would you choose for your tractor? #26
Dirt and dust are not really as big a problem as you might think, I use my wipers a lot and blow the side windows off from time to time. You won't find an open station ag tractor anywhere down here and if you ever disked a burned wheat field you'll sure know why.
   / If you could only choose hydro or cab what option would you choose for your tractor? #27
Depends on the amount of open land to me. I have 50 acres wide open, and the sun, dust, birds, bugs, and when we have "winter" is just too much for an open station tractor. When the Deere is here, that cab station is like I died and went to heaven. No comparison.
   / If you could only choose hydro or cab what option would you choose for your tractor? #28
Both are important but the cab is more important. Your personal protection from sun, bugs, extreme temperatures, and dust is a given. That being said, cab or not, wear your sun protective clothing, hat and broad spectrum spf 50 or greater sunscreen. Melanoma and nonmelanoma skin cancer is reaching epidemic levels in this country. The numbers continue to grow.
If low hanging limbs are a problem and you and the protective pipe frame is not an option (innovative idea, great pictures TripleR!), consider trimming them with a chain saw like the Stihl HT 130.
   / If you could only choose hydro or cab what option would you choose for your tractor? #29
Like the majority have said and what it appears you went with......a Cab. I am currently looking to purchase a LS XU6158C. Have been using an open station Mahindra for the past 10 years. It has been a great tractor, but when doing hay and rotary cutting during June/July I sure dream of having a cab.
   / If you could only choose hydro or cab what option would you choose for your tractor? #30
Yep, between the two, I would also choose a cab.
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
Hustler super Z zero turn (A56857)
Hustler super Z...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
19010 (A55851)
19010 (A55851)
John Deere 5105M (A53317)
John Deere 5105M...
