If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #751
It's in the bag! ;-)
Is that a wrist watch?
   / If there are aliens, what will they look like? #752
How I know the earth is a sphere.
I set up a theodolite, I went in a straight line for four miles, turned 90-degrees left, went another four miles. Then turned another 90-degrees left, and went four miles. And then turned another 90-degrees left, and ran another four miles. If the earth us flat, I should have been close to where I started. But, I ended up quite aways away from where I started. Because planar trigonometry doesn’t work at all well on a sphere.
   / If there are aliens, what will they look like? #753
   / If there are aliens, what will they look like? #754
   / If there are aliens, what will they look like? #755
Let's face it. None of the things you are promoting can be observed. Not one. Everything that we've been promoting can be observed. All of it. We have photographic evidence as well as our personal observations, as well as the word of nearly 600 people that have been in orbit, as well as the many tens of thousands of people that supported their missions. No one can keep a conspiracy of that many people in tact. It's not possible.
And let's leave the my religion is better than your religion discussion out of it.
   / If there are aliens, what will they look like? #756
In your video "proving the rocket hit something" you want us to believe you, yet the same video shows the curvature of the earth which I am sure you will make up some "proof" that it really is not showing that.
The curvature of the earth can easily be distorted by a lens. However, read the comments section of that video. In it, as I mentioned before, it is explained why the noise cuts off (the rocket motor finished, so yes, it got quiet), and it explained why the rocket appears to suddenly stop spinning (it had a device to stop the spinning for a reason). I put links in there to explain it all.
The rocket didn't hit anything, and all was explained. He's ignoring that, just as he's ignoring the wind turbines over the horizon example because it doesn't fit his belief that it's all perspective. Nor will he believe the dozens of videos out there that show huge container ships going over the horizon. If the earth's surface was flat, perspective would show the entire object decrease in size proportionally until it was a dot. However, that doesn't happen in any of the videos.
   / If there are aliens, what will they look like? #758
Someone needs to start a flat earth thread. That could readily drift off into perpetual motion mechanisms!
It would be a lot of fun for those who enjoy that silly stuff.
Me? I'm trying to figure out aliens!
   / If there are aliens, what will they look like? #759
And then there's the whole sunset thing, where I've watched the sunset while sitting stationary on a runway in a running airplane, then taken off, climbed, and watched the sun come back up. Then watched it set again. Literally, tens of millions of air travelers have witnessed this.
This guy does an excellent job of presenting reasonable conclusions from observation. Two thumbs up.
   / If there are aliens, what will they look like? #760
How about Tardigrades?
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
208320 (A58375)
208320 (A58375)
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
JOHN DEERE 6430 PREMIUM TRACTOR (A60430)
JOHN DEERE 6430...
