If it slipped on, it will problably slip off...
   / If it slipped on, it will problably slip off... #1
BTDT
Veteran Member
North Texas
IH M Farmall-propane powered, H Farmall (father-in-laws), Ford 1300 diesel
When I was building my suspension bridge, I was using a come-a-long to adjust height of deck of bridge. I would try to take into account what might go wrong, as I was suspended over the water about 15', and over the land about 10'. I would lay down the floor made of expanded metal until I run out, then would work off of a 2x6 so I wouldn't have to stop working when I run out of material and could keep extending the framework and cable assemblies. Well, something I hadn't planned on was the plastic handle on my come-a-long slipping off. I had re-adjusted ropes, chain, etc, positioned my board in the place I was going to sit, and grabbed the handle on the come-a-long to ease myself into position to sit on board, when the handle slipped off. I continued over backwards and just happened to hit the water. I usually always expect the unexpected, but this was a complete suprise. I didn't get hurt (this time), but had I been over the land when I hit it could have ended differently. Pictures of bridge construction are in the photo section at bottom in "Other forums" if you care to take a look.
   / If it slipped on, it will problably slip off... #2
Glad to hear you landed safely - but it is pretty funny.
Long time ago working in a factory I was helping a friend to tight transmission idle shaft. The wrench gave in and I flew in a box of gears; they really hurt your butt and back when you land on them.
   / If it slipped on, it will problably slip off... #3
I can't find the pictures. Do you have a link?
   / If it slipped on, it will problably slip off... #5
Thanks. That bridge is very cool. Nice work!
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
