Calling all diesel experts,
I have a B 2100 that's developed a small issue that I'd like to run by you. The tractor starts and runs great, but when I bring the tractor back to idle, the engine drops about 100 RPM two to three times before settling in at 1000 RPM.
It almost sounds like load is hitting the engine or maybe a valve is cycling, then, after two or three cycles (drops in RPM) about 5 seconds apart, idling stabilizes.
Any ideas what may be causing this? The tractor will do this without any pumps engaged, loader and three point in float (or not), tranny in neutral, no load on anything.
Throttle ups are normal (stable), and power output is fine.
Kubo
Kubo
