Idle time vs wear and tear on starter
   / Idle time vs wear and tear on starter #21
Same here, not below 1500 rpm unless idle prior to a shutdown.
You have a mix of people posting replies here. Those with and without DPF. There’s a difference.
And also those with a turbo and those without one. That makes a difference as well.
I have an old tractor without DEF and without Turbo, I'll let it idle at the low end at whatever the minimum mechanical stop allows.
I have another tractor without DEF but with a Turbo, it's supposed to need a warm up and cool down time and a 1200 rpm for the turbo, so I follow those guidelines. I.e. 1200 rpm is the idle speed except for the 2 minutes of warm up and cool down. I run the engine while changing implements, except when attaching the pto shaft or connecting/disconnecting the hydraulics.
   / Idle time vs wear and tear on starter #22
To me, the age of the machine matters a bit. If it's new, I wouldn't want to rack up hours idling. If it's old, I don't feel it matters as much.
Sometimes it is a matter of noise, smoke or safety.
It's what I like about Diesels over Gasoline engines. When warm, you can barely operate that starter switch quickly enough and it is running again.
   / Idle time vs wear and tear on starter #23
I idle mine at 1200-1500 rpm when at rest and normally do not shut it off unless I won't be using it for 15 or more minutes. 850+ hours and runs like a champ and it has not impacted the regen cycle. In my opinion, constantly shutting off and restarting an engine, gas or diesel, is harder on the engine than simply allowing it to idle. I priced out a new starter for my XG3037 just out of curiosity and about fell over with a stroke. Check for yourself....guarantee you will be surprised and bewildered!
   / Idle time vs wear and tear on starter #24
Many many factors in the “which is better” calculation..
....not just wear on starter, but factor in the wear that additional thermal expansion/contraction stop-start cycles has on....gaskets, seals, hoses, thermostats, bolts, bearings....everything really....
....compared to the wear of it continuously running.
The calculation gets tricky.
IMHO, I think that not only should most vehicles and tractors have odometers, and hour meters, but a cycle ( or start-stop) counter too.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
man basket 72 '' (A56857)
man basket 72 ''...
500BBL SKIDDED FRAC TANK (A55745)
500BBL SKIDDED...
