idle problems
/ idle problems #1
hardluck
Hey Guys,
I had to take the injector pump off to change the glow plugs on my Bloens G-274 and now it won't Idle. Does anybody have words of wisdom. :confused:
/ idle problems #2
Well, I'm a newbie to tractors, but have had some experience with diesels.... Timing on the injector pump is pretty critical; if it didn't get put back precisely where it was (from a rotational perspective), it will create problems. Did you mark it before you removed it? Is there a notation as to position in the manual? It may be possible to "ballpark" it by rotating it a tiny bit and trying; typically, setting injector pump timing by the book means disassembling the entire front end to line up all index marks on drive chain sprockets, much the same as for replacing a camshaft or timing chain/belt.... Hope this helps.
/ idle problems #3
You may want to refer to instructions in: Set timing TL2300 engine E3AE
It will be the same.
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2001 FORD F-150 LARIAT TRUCK (A64276)
2001 FORD F-150...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2014 Caterpillar 420F (A64126)
2014 Caterpillar...
