idle problems
   / idle problems #1
hardluck
Hey Guys,
I had to take the injector pump off to change the glow plugs on my Bloens G-274 and now it won't Idle. Does anybody have words of wisdom. :confused:
   / idle problems #2
Well, I'm a newbie to tractors, but have had some experience with diesels.... Timing on the injector pump is pretty critical; if it didn't get put back precisely where it was (from a rotational perspective), it will create problems. Did you mark it before you removed it? Is there a notation as to position in the manual? It may be possible to "ballpark" it by rotating it a tiny bit and trying; typically, setting injector pump timing by the book means disassembling the entire front end to line up all index marks on drive chain sprockets, much the same as for replacing a camshaft or timing chain/belt.... Hope this helps.
   / idle problems #3
You may want to refer to instructions in: Set timing TL2300 engine E3AE
It will be the same.
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2007 FONTAINE TRAILER CO. 48X102 SPREAD AXLE STEPDECK (A52472)
2007 FONTAINE...
2014 PETERBILT 388 (INOPERABLE) (A52472)
2014 PETERBILT 388...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
