Idle curiosity on clutch disc types
   / Idle curiosity on clutch disc types #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Just saw a clutch disc with 5 (give or take) pads, vs a standard 360 degree "brake shoe material" type clutch disc. that you normally see. Anybody have any real world info about why you would prefer one over the other. Are the pad types made out of a really hard material like ceramic or something similar?
Thanks,
Mark
   / Idle curiosity on clutch disc types #2
You guessed right. The pad/button type clutch disc are generally for heavy duty or severe service. They can be "grabby" because they lock up quicker than standard full face discs.
SimS
   / Idle curiosity on clutch disc types #3
SimS
They also require you to replace your flywheel more often as they wear the surface more than an organic clutch face. But they are an awesome solution to a hard clutch use situation like heavy front end loader work.
   / Idle curiosity on clutch disc types #4
We put a 5 pad ceramic in our older gear tractor when we did the clutch last year. It had a standard disc in it before. When we went to order the pressure plate and clutch disc they asked do you have a loader on it, yes and also with substantial snowblower use it makes sense to spend a little more for the 5 pad ceramic clutch disc and reconditioned pressure plate with the heaver springs for hopefully longer clutch life. It has only been a 100 hours so far but it seems fine and the clutch engagement is smoother than the worn out disc we replaced.
Thanks guys for your answers. I always wondered and thought maybe I was missing something.....guess not.
2016 Ford F-150 Single Cab Pickup Truck (A55973)
2016 Ford F-150...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2014 JCB 930 (A53317)
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
