Idiot friend hooked battery up backwards
/ Idiot friend hooked battery up backwards #1
ccsoxfan
elko, NV
Case 580E
My friend borrowed my Case 580E tractor and hooked the battery up backwards after charging it. He said the posts spark and now I have no charge and no power.
I would assume that I need to replace fuses, but I cannot find the fuse box.
Any ideas
Thanks for any help
/ Idiot friend hooked battery up backwards #2
/ Idiot friend hooked battery up backwards #3
I doubt it's a fuse problem. You have probably fried the diaodes (sp?) in the alternator. Disconect the wires at the alternator. then put a properly charged battery in correctly. It will probably work except for the charging system. The sparks are current flow back through the alternator. If this works as I suspect you can replace the diaodes or just get a rebuilt alternator
(2) 15 Gal Sprayers, 25 Gal Sprayer, Honda Pressure Washer, Wheel Barrel (A64119)
(2) 15 Gal...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61574)
2014 Crossroads RV...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61573)
2020 Mack Anthem...
