Idiot friend hooked battery up backwards
/ Idiot friend hooked battery up backwards #1
ccsoxfan
elko, NV
Case 580E
My friend borrowed my Case 580E tractor and hooked the battery up backwards after charging it. He said the posts spark and now I have no charge and no power.
I would assume that I need to replace fuses, but I cannot find the fuse box.
Any ideas
Thanks for any help
/ Idiot friend hooked battery up backwards #2
/ Idiot friend hooked battery up backwards #3
I doubt it's a fuse problem. You have probably fried the diaodes (sp?) in the alternator. Disconect the wires at the alternator. then put a properly charged battery in correctly. It will probably work except for the charging system. The sparks are current flow back through the alternator. If this works as I suspect you can replace the diaodes or just get a rebuilt alternator
Caterpillar Service Letters from 1980's (A63117)
Caterpillar...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Asphalt Melter (A61572)
Asphalt Melter...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
2025 Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
