Buying Advice Identifying 1967 Ford 4000 / 41014 C
   / Identifying 1967 Ford 4000 / 41014 C #1
stileseverett
Franklin, NC
1956 JD Model 70, 2976 JD 2040, 1977 JD 410 back hoe
Sirs: Just purchased a fine old Ford 4000 from a neighbor in the Eastern Transvaal of South Africa to use on our farm there. The plate under the hood lists it as a 41014C, with a serial number that appears to be different than used on US-based tractors. The decals on the hood call it a 4000.
Parts should be available locally there; if not, are all 4000's the same if I need to carry spares from the US?
photo of number plate attached.
Thanks a lot!
Everett Stiles
Macon County, NC
   / Identifying 1967 Ford 4000 / 41014 C #2
I'm no expert on this but Ford did manufacture a lot of tractors in the U.K. As to which exact models I'm not sure but you may want to start researching that to see if yours is perhaps from the U.K. Parts availability should be good no matter where it was made.
Thanks....looking forward to getting back to the farm and work the old horse....
2009 John Deere 468 (A50120)
2009 John Deere...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
