Backhoe Identify 555 backhoe
/ Identify 555 backhoe #1
VALLEYDRG
Roseburg
FORD 555
Looking at a ford 555 backhoe and was going to get the manual but not sure if it's a 78 or 88. Numbers I found behind starter are C3NN 7006 C then maybe 2 0 ? The date code I can see 8E 8 ? And is why I am assuming 78 or 88. I will check numbers better again later this week.
Ok got more numbers today the other numbers i think came off of transmission. These came off of engine below starter date 8E 9 then below that D5NN6015G these numbers are both on a there own tag attached to the lower part of the engine.
/ Identify 555 backhoe #3
None of what you posted is a model number. Look for a stamped number on a flat part near the starter on the transmission. That would help out alot.
The D5 part of the block casting code tells me its a 1970's. So I'm gonna go with a 1978
Finally got to finding serial number stamp below starter. what does this tell me *D311802* and above that on a tag I also found D5NN6015 G and a date tag 8E 3 I think these must be engine numbers? Since my original post previous owner thought he remembered it as a 1982 is this correct with the stamp ending with 2. Thanks for any help.
/ Identify 555 backhoe #6
8e3 is part of a date code. There should be o e more letter after it though, but that last letter would only indicate what shift it was assembled. 8 is the year, e is may, 3 is third day of the month.
D of the block casting code means 1970's as I already said. So 1978 based on the "D" of the block casting, and the "8" of the date code
/ Identify 555 backhoe #7
Serial number on my 575E is stamped in the frame by right side of engine.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2023 FONTAINE INFINITY FLATBED TRAILER (A59823)
2023 FONTAINE...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
