Ideas to Fix or Replace Hydraulics on Trailer?
   / Ideas to Fix or Replace Hydraulics on Trailer? #1
BxB301
Lincoln
I inherited an old trailer.
By buddy who owned it previously, never messed with the hydraulics, and the trailer worked as a trailer, thus he didn't care.
I would like to fix it, just so I can use the trailer to its full potential.
It looks like its has long weird cylinders connected to each wheel, fed via brake line, and a manual operated pump in the center.
I think you can raise or drop the trailer as needed. It might lay flat? or raise? Not really sure.
Look like the pump & trailer was patented in the late 40's
At this point, the pump is seized and does nothing. Parts are surely non existent.
Any ideas where to start?
   / Ideas to Fix or Replace Hydraulics on Trailer? #2
Seen a setup similar on an ice fishing RV. Electric pump of course. That unit would lower flat to ground to park and raise to travel. Doubled as a toy hauler and made loading breeze.
I expect when pressure is removed the trailer should drop and pumped back up to ride height. It may have a mechanical lock for keeping it up
Yeah, it does. They can be seen at the end of the cylinders in the 2nd photo.
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
