Ideas to dispose of land clearing waste
   / Ideas to dispose of land clearing waste #11
I’ve given away a bunch of logs off clearing jobs. It’s easy to do this time of year.
   / Ideas to dispose of land clearing waste #12
Hardwood? yes
Pine? not easy
   / Ideas to dispose of land clearing waste #13
   / Ideas to dispose of land clearing waste #15
The cheapest option is to burn but that also takes the most time.
If you want fast, hire a 30 ton excavator to dig a big hole and bury everything. You can then rent a forestry mulcher to do final cleanup. Would probably be cheaper than hiring someone to haul away...around here at least.
In my area you need a CDL to haul over 10,000lbs truck and a CVOR and commercial insurance. $500/yr just to get your annual inspection done...not cheap anymore...even farm plates are now forced into annual inspections.
   / Ideas to dispose of land clearing waste #16
Seems like that would be a massive hole to bury all that and make all that land worthless to build anything at least near that hole because of decomposing wood for how many years
   / Ideas to dispose of land clearing waste #17
Yea I wouldn’t burry that mess. Where I live it usually isn’t possible to dig a hole that deep but my dad tried that about 20 years ago a few counties over where you actually can dig a big hole. That hole is probably still sinking as the wood rots. For a couple years it was settling a lot like several feet at a time. I would clear a bigger spot and just shove it all in the corner out of the way before I buried it.
   / Ideas to dispose of land clearing waste #18
I agree on the BioMass Energy plants - there are several in New England. When we had 4 acres cleared they chipped everything except the logs and sold the rest to Shiller Station in Newington NH for 30$ ton - took 6 tractor trailer loads of chips. Shiller stopped taking wood waste in 2024, but depending your location there are plants in ME MA and CT that still burn wood waste.
It's a matter of getting it chipped. I would rent a large chipper - 12-14" and feed it with an excavator - probably get a lot chipped in a few days. For the rest of the dirt/roots/rocks burning is best - just get a few piles going and keep feeding it for a few days.
Then dig a hole and bury the remaining bits that dont burn. It's a lot of work clearing ground - what are you doing with the stumps? That was my biggest cost - $1750 a tractor trailer load 4 loads.
   / Ideas to dispose of land clearing waste #19
We can burn but nothing larger than 5" radius. A lot of those logs are bigger then that. As for the other materials there is a lot of dirt mixed in and it tends not to burn.
Are the cops going to come if you start a fire with pieces over 5”? If you piled up a pile as big as a truck, let it burn down some and repeated the process you would be done in a couple days. It’s going to take much longer to chip that with anything less than a belt feed behemoth chipper.
33ft Dovetail Flatbed Trailer (A55315)
33ft Dovetail...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2020 MACK P164T (A58214)
2020 MACK P164T...
