Ideas for rotary cutter build
   / Ideas for rotary cutter build #1
deanwerden
wyoming, on
2010 Cub Cadet sc2400
I would like to build a rotary cutter for my compact tractor , 4 feet wide but would like to use 2, 2ft blades to keep the length down, I always though a compact with a 4ft rotary cutter looked ridiculous. My idea was to either buy one gearbox and connect it to the blades with either sprockets or belts. I am wondering if a gearbox could be eliminated with the use of a double or triple v belt arrangement that wraps up 90 degrees with a hub for the pto shaft. This cutter will be used mostly for tall grass with the occasional sapling probably no more than 1". I have cut the same area of long grass with my mid mower before fully raised and It did OK but was slow going. I just see no reason why a double belt arrangement wouldn't work as my mid mower only uses one belt and will stall the engine out before the belt slips (as far as I can tell).
My idea is to use 2 flanged bearings spaced a few inches apart for the blade shafts, bottom will have a hub for blades and top obviously a pulley . I will then build a small platform where I can mount 2 more pillow blocks with a small stub shaft that will have a pulley on the rear and the front will have the pto shaft facing the rear of the tractor. Then I will obviously need a few idler pulleys to make the turn 90 degrees .
Thoughts? Any reason this kind of setup wouldn't work?
   / Ideas for rotary cutter build #2
Sounds like a complex solution to a simple problem. 2-2' blades is probably larger than what would come on a 48" shredder? Those cutters are usually pretty compact anyways. What it sounds like your wanting to build is more like a rear finish mower but that can handle a 1" sapling. Have you used a 38" rotary cutter and don't like it or you just want a project to work on?
I really like the KISS method and to not reinvent the wheel
Brett
   / Ideas for rotary cutter build #3
Buy a used 4-foot brush hog for a few hundred bucks and rebuild it to your specifications. You can sharpen the blade to give a cut like a riding mower or you can grind the cutting edge with a larger radius to cut brush.
   / Ideas for rotary cutter build #4
Think you can realistically build something for less than $850? Here's a 4' mower at Agri-Supply for $849.99
4 Ft Finishing Mower, 3 Point Mower, Rotary Mower
Personally I think if you mow a 1" tree with anything with a 2' blade and a belt you will have bad results for your blade or your belt. My dad had a 5' 3 pt. hitch mower and every time he decided to mow the "thick" grass he would have to buy an expensive belt. If you want a 4' bush hog get a 4' bush hog, if you want a 4' mower get a 4' mower. I think you will have a lot of time, effort & money in something you can already buy for not a lot more or less than you will have in it doing it your self.
Brett
Yes you are correct I am essentially looking at building a rear finish mower that can take care of a few saplings in the way. Similar concept to the big 8'+ bush hogs that are sometimes a 2 blade design. I am going to build one either way just thought this design would take up less space both when in use and in storage.
I am not looking for a finish mower I am looking to build a rotary cutter with a similar design to this
1 foot bushhog - Bing images
   / Ideas for rotary cutter build #7
Y E S .
   / Ideas for rotary cutter build #8
If the blades are not allowed to free swing like a brush hog what happens when you hit more solid like a sapling? If going slow enough it will probably chew through it. If a little to solid what gives at that point? Blade bend, belts slip, stub shaft bends, etc..
the blades will be free swinging like bush hog
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2014 FORD F-250 (A50854)
2014 FORD F-250...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
Unused 2025 CFG H15R Mini Excavator (A49461)
Unused 2025 CFG...
John Deere X740 Mower (A50514)
John Deere X740...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
