Ideas for Hydraulic Line routing......LS R4041 H
   / Ideas for Hydraulic Line routing......LS R4041 H #1
Underdog57
W Michigan
LS R4041H
I routed hydraulic lines from the rear remotes to the front of loader over the top of the differential and up the left side of tractor. I had two 130" and two 48" L x 3/8" Hyd lines made and it fit perfect! There is a lot more room on the left side. I found 15' of hose protector sleeve at TSC for about $15 and sleeved the total length. I used 3/8" couplers in the middle on the loader arm and 1/2" on the two ends.
Just thought I'd show how I did it. :)
   / Ideas for Hydraulic Line routing......LS R4041 H #2
That's pretty much exactly what I did except I looped up and over my top link and then ran down the left side. I also sued 1/2" couplers in the middle connection to get all the flow I could to the front in case I ever needed it for an implement. Thinking hydraulic PHD in the back of my mind.
   / Ideas for Hydraulic Line routing......LS R4041 H #3
Nice Shop.
   / Ideas for Hydraulic Line routing......LS R4041 H #6
What is the coupler in the middle for
   / Ideas for Hydraulic Line routing......LS R4041 H #8
I need to do something similar with my P7010C. I don't really want to drop $1000 for a electro-hydraulic 3rd function kit. I played around on Discount Hydraulic Hose and for about $200-$250 I can build a similar setup like you did. Originally I did not want to tie a remote valve up permanently with this setup, but heck, I have 3 of them.
I did something similar on my Farmall 504 but I had a 3 spool valve for the loader... And no cab... I need to get this done soon so I can continue to use my grapple.
Slick job on your 3rd circuit. I plan to emulate.
CT
   / Ideas for Hydraulic Line routing......LS R4041 H #9
That is a great install. where did you get those mounts at the bucket where the lines terminate
I got most of the fittings at Hydraulics Direct.com. The hoses I had made by the mechanic where I work.
Whoops! I was wrong CT, I DID get my parts at Discount Hydraulic Hose ,including the support clamps, NOT at Hydraulics Direct. Sorry for the confusion. :(
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
IH 1066 Tractor (A50514)
IH 1066 Tractor...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
2019 CATERPILLAR 262D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
