Ideas for a big lawn roller
   / Ideas for a big lawn roller #1
rvtech
Sunbury, Ohio, U.S.A.
2006 John Deere 2305
I want to vastly improve my 5 acres of lawn for faster tractor speed when mowing. I asked a friend that used to work at a golf course how they smoothed out the fairways. He said they made some very large/heavy rollers and towed them around for 2 weeks every spring. He used 200 gallon fuel tanks, welded bearing carriers on the ends and then made a hitch, installed a bung in the end and filled with water.
Anyone have any good ideas of something that will make a good heavy roller?
   / Ideas for a big lawn roller #2
How about just a 55 gallon drum - Rod down the middle/fill with water. Or fill with concrete/rocks if you want something more permanent. Another option might be some kind of heavy drainage pipe also filled with concrete.
   / Ideas for a big lawn roller #3
I thing 3 lawn tractor water rollers would be easier on your lawn. Just make an extension rod for the 2 outside rollers. Baking up would be impossible though. you could link them in a strait line though
   / Ideas for a big lawn roller #5
55 gallon drums usually have a ridge in the center, or two equally spaced, so that would put more ruts in your yard.
A large piece of PVC pipe if your in the plumbing field, used propane tank if your not.
David from jax
   / Ideas for a big lawn roller #6
I like the propane tank method, a 330gal is maybe 6 feet wide the round edges dont dig into the ground when turning.
I like the propane idea too. I'm going to call my supplier to see when I'm due for a new tank.
   / Ideas for a big lawn roller #9
I like it!! I think I'm going to do the same. It would be really neat to make one like above with a 3ph so that when it's empty it could be lifted and moved. But that would probably be too difficult and not necessary. Be careful when welding used propane tanks though!!
   / Ideas for a big lawn roller #10
The one that was made from a large propane tank is impressive, but I wonder how he would be able to control it if the ground isn't level. I know that it would push a small tractor around quite easily. Reminds me of the tail wagging the dog.:D
Dusty
2005 Ford F-250 Pickup Truck (A44572)
2005 Ford F-250...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
2000 Ford F-150 4x4 Ext. Cab Pickup Truck (A42744)
2000 Ford F-150...
2017 Ford F-450 Liftmoore 4000X Crane Truck (A42742)
2017 Ford F-450...
2019 VALTEK 2500HP FRAC PUMP (A45333)
2019 VALTEK 2500HP...
Tennant ATLV 4300 All-Terrain Litter Vacuum (A42742)
Tennant ATLV 4300...
