Idea,Design and fabrication
   / Idea,Design and fabrication #1
4shorts
Elite Member
Bay Roberts, Newfoundland
Kubota 5740,BX25D
Everything starts with an idea and today was no different. My head is full of ideas and the wife says I'm nuts and she's probably right.
Anyway my new Kubota Grand 4240 had this tube on the loader attachment. I said to myself that seemed to be a terrible waist of space and seeing I needed a place to put a tow sling I decided to use that space for it.
I had to have some way of capping the ends of the tube so this is what I did. It was all made out of scrap aluminum. It was machined and then Tiged and machined again. I wasn't to particular about the appearance of the weld because I knew I wanted to machine it anyway. The O rings were used to keep the caps in place but the grooves had to be machined just right or they would be either to tight or to loose. After that was done the parts were etched primed and painted.
   / Idea,Design and fabrication #3
Very impressive workmanship.
Eddie
   / Idea,Design and fabrication #4
You should consider selling those and make a few $$$.
   / Idea,Design and fabrication #5
I love it when a guy does a perfect job...great work!
Now, be sure to post your pics as clickable thumbnails for us slow connection guys.
Thanks,
   / Idea,Design and fabrication #6
Excellent, I have the same crosstube on my Deere's loader.
Plus if you store your tractor outside, bees and wasps will be less likely to use the tube as a nesting site.
Thanks guys. I wanted to try and do the mods I've done without actually altering the tractor. As with the light bar and these end caps I've only either used the tractors existing hardware or in this case it's just a push and pull and no damage to the tube. Glad you all like it and I'll be sure the next time to use the thumb nail system :) Appreciate your comments
   / Idea,Design and fabrication #9
Now thats a job!! I was reading replies wondering how does it hold in - than scrolled back up and noticed those 2 O-rings. Tip of the hat to you, sir, it is great to see man made perfection!
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
1323 (A57192)
1323 (A57192)
2012 Ford Escape XLT SUV (A55853)
2012 Ford Escape...
