JasperFrank
Elite Member
- Joined
- Nov 23, 2018
- Messages
- 3,008
- Tractor
- Ford 1220
Tj, the mass of the ice is the same as the mass of the water. The state of a material does not change its displacement. You got the lesson wrong. The water level didn't change. Do it again today. You will see there is no change in the levels. Your teacher should have been fired. Ice is bigger than water, the oxygen makes an expansion when it goes to a solid, but it isn't heavier, its the same "weight." So do the experiment, Fill a glass half way with water, put in one ice cube so that it is freely floating, measure with a line where the water is. It will be the same level after the cube is melted.
