IBM laptop died, need sugestions
   / IBM laptop died, need sugestions #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Wife has an ibm laptop running xp ( don't know the model.. but it had xp natively on it.. it wasn't an upgraded unit from 98..e tc.. ). She downloaded some email on it about 5pm, and shut it down like normal. she got to work tonight, and started the thing, and it came up to the windoes screen, but the task bar never came up... she got impatient with it and did a hard power off by holding down the power button ( I told her this was probably a bad thing to do, since it was obviously taking extra time to boot for some reason and she should ahve given it more time ).. in any case, now on subsequent boot attempts, the laptop displays either an invalid media notice, please check cable.. or operating system not found / unable to be loaded.
Any ideas on where to go from here?
unit has a floppy drive and a cd /dvd rom.
any advice is appreciated.
soundguy
   / IBM laptop died, need sugestions #2
Sounds like the hard drive is failing. The hard drive is a storage media (thus the "invalid media" message). It may almost work sometimes, giving you the "operating system not found" message because it can't correctly read one or more of the Windows files.
You might try pulling the hard drive and putting it back in. It's pretty easy to do that on a laptop.
If that doesn't work, try booting from a boot-CD or a Windows CD if you have one. If that works, try to access the hard drive C: and see what happens.
   / IBM laptop died, need sugestions #3
TedLaRue said:
Sounds like the hard drive is failing.... You might try pulling the hard drive and putting it back in. It's pretty easy to do that on a laptop.
I agree, it is probably: A. a bad harddrive, or B. a bad connection to the harddrive. if it is B removing and reinstalling the harddrive can reseat any loose cables, if it is A, removing and reinstalling the harddrive probbaly wont do any harm.
if you dont have a boot CD or a windows CD, try Ubuntu.com for Ubuntu install CD, this will let you boot up and get into a graphical environment relatively painlessly.
Aaron Z
   / IBM laptop died, need sugestions #4
I have seen invalid media / operating system not found when a non bootable floppy disk has been left in the drive. Drove me crazy for a while. And I'm supposed to be a software professional. :rolleyes:
Bingo guys.. just got it fixed. When she got home I started looking it over and sure enough.. the hdd is easilly removable, and was unseated about 1/8 inch.. I pushed it in and clicke dthe little plastic door shut, and it booted ont he 1st try. ( i still performed a full backup though.. just in case..!! I just got done with the backup.. )
Thanks
score one more for the TBN tech support team.
soundguy
   / IBM laptop died, need sugestions #6
Thanks
soundguy
Glad you found it. I hate laptop hard drives that can pop out like that. IBM and old NECs are famous for that. I'm surprised it isn't held in place with a screw.
   / IBM laptop died, need sugestions #7
Gotta love an easy fix!
Had a dell that had to have motherboard replaced twice, fortunately still under warrenty.
And hang onto that XP OS.
Yep.. not looking forward to vista!
soundguy
   / IBM laptop died, need sugestions #9
I happen to like vista but if it were me I would hold out for Microsoft 7, Now I will have another operating system to figure out, LOL
When is 7 'slated' to come out?
soundguy
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A55788)
2008 Ford F-250...
