i1042 Cub Cadet Dual Hydro-Static Transmission One Locked Other Free
   / i1042 Cub Cadet Dual Hydro-Static Transmission One Locked Other Free #1
daveguertin
Rochester, MN
Cub Cadet
I jacked up the rear-end of my 2009 i1042 Zero Turn Radius Cub Cadet. I disengaged both transmission with the pull-rods in the rear and locked them. Both rear wheels should be free-wheeling so the tractor can be pushed manually easily if needed. I noticed the right wheel turns freely, but the left wheel is locked or engaged like it would be in normal operation.
I just completed installing a new drive belt because the other one slipped or stuck and it burnt on the drive pulley. After I installed the drive belt and reassembled the body/dash/electrical parts, I sat on my tractor to start it. When I turned the key the headlights came on, but there was no solenoid click and no starter turning the engine. The only place I figured I might have a problem was with the two safety switches for the brake and seat since this is the only area I disturbed during belt replacement.
In tracing the brake switch I noticed the tractor would not move when I disengaged the two transmission, so I thought the brake might have locked up. But after I jacked up the rear-end and tried rotating the rear wheels by hand, only one of the wheels turned. The other was locked up.
Has anyone experience this situation? Do you think it is a brake problem or a transmission problem? Does the brake lock up the transmission? If so, is there a release to free it up again?
Information is appreciated, David Guertin Rochester, Minnesota:cool2:
   / i1042 Cub Cadet Dual Hydro-Static Transmission One Locked Other Free #2
Dave - am sending you a private msg
John Deere 7H19 (A56469)
John Deere 7H19...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED WOLVERINE TDB-11-84W 84" BUCKET (A57193)
UNUSED WOLVERINE...
Blue Diamond 72" Quick Attach Bucket (A56469)
Blue Diamond 72"...
UNUSED FUTURE D5T-34" HYD TILT BUCKET (A57193)
UNUSED FUTURE...
2017 Ford F-250 Reading Service Truck (A55852)
2017 Ford F-250...
