I Went To Purchase A New Mini-Excavator And This Happened.....
   / I Went To Purchase A New Mini-Excavator And This Happened..... #21
A car collector friend did a special order and contract said less than 4 miles at the time of delivery…
He went to pick up his new special order and it had 237 miles… salesperson took it home over the weekend…
Situation got ugly and a significant accommodation made…
   / I Went To Purchase A New Mini-Excavator And This Happened..... #22
i agree machine is not remotely used, sat on a lot for a little bit, no digging machine would be that clean in 7 hours, the heat shield is fine and has no issues either. I'm starting to wonder if people here actually use there machines, as mine looks like this from a single rainstorm, even after i clean it. A power wash should have been in order.
   / I Went To Purchase A New Mini-Excavator And This Happened..... #23
You’re right. That machine is brand new. Even the rocks wedged in the tracks are brand new. Spotless 🙄
   / I Went To Purchase A New Mini-Excavator And This Happened..... #24
Dented? Gouged. Not sure. Looks kinda crappy.
Lower bolt bracket already rusting. Bad factory paint coverage?
Air filter cover not put on correctly.
Is kubota getting sloppy at the factory, or did someone remove the cover on a “new” machine, and why so?
At least the factory person who applied the kubota sticker , cared enough to orient it correctly with the “TOP”, but not whoever last assembled it.
Even the rubber drain nipple on the air filter cover looks like it’s spent some years in the sun .
Maybe that’s just the picture? Not sure
Definitely is not new. Almost new, slightly used, yes
You realize that’s the muffler with a heat shield right? Exhaust manifolds are always rusted literally every single one. I’ve never seen the heat wrap not be wrinkled either. Moving the air filter cover one notch around would take 5 seconds.
   / I Went To Purchase A New Mini-Excavator And This Happened..... #25
Looks like it’s fresh out of the factory 😂
   / I Went To Purchase A New Mini-Excavator And This Happened..... #26
Exactly. It's not about what other people want. It's about what you want and you paid for.
   / I Went To Purchase A New Mini-Excavator And This Happened..... #27
lol sat on a dirt lot? guess they shrink wrap the machines were you live. I live next to a dealer for kubota, most of their machines look worse then this brand new
   / I Went To Purchase A New Mini-Excavator And This Happened..... #28
Thanks for pointing this out. My last name is not Kubota, and I don't make excavators, so I am not familiar with every part. I thought this was a thick metal part that had somehow gotten mangled.
The hours are the big issue, though. Used is used.
91013 (A48082)
91013 (A48082)
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2012 JOHN DERE 310K BACKHOE (A51406)
2012 JOHN DERE...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
