I want to buy a new 425 this year but ...
   / I want to buy a new 425 this year but ... #21
I do did not ask the wattage. I think the advantage of this is that being in the engine compartment more of the heat will reach things that need it. Both hydraulic and engine need heat, and they will get some. A magnetic heater on the outside will not send any heat to the engine.
In my experience, the EH72 isn't happy trying to start while dragging a hydraulic pump with frigid oil. For at least the last 5 or 6 years, I have used one magnetic block heater on the top of tram pump and another on the hydraulic reservoir inside the tub. I also installed a bigger battery and heavier battery cables. That has made the difference between starting under protest and refusing to start at all when the temperature is much below 40*F. If it's well below freezing, I've often draped a tarp over the engine cover to hold in some heat.
The new big block has started at 28*F once with no added heat. I'll see if it repeats the performance when winter really sets in.
   / I want to buy a new 425 this year but ... #22
It's not a lot of difference though.
   / I want to buy a new 425 this year but ... #23
Ooh, I looked at your post again. Your way is fine. You just have to move the heater out after the start.
   / I want to buy a new 425 this year but ... #24
If I was going to get a heater, I'd probably get one or two of these heating pads and stick them on the side of the hydraulic tank inside the engine compartment where they wouldn't get torn up:
https://www.wolverineheater.com/Engine-Oil-Heaters-for-Cars-s/1814.htm
Then I'd go down to my local u-haul store and pick up one or two of these mover's quilts and drape them over the hydraulic tank and engine compartment:
Object moved
And I'd get a heavy duty 20Amp X-10 AC outlet in my garage like this:
X10 Heavy Duty Appliance Receptacle, 20A, 240VAC
So I could turn it off and on from inside the house with a cheap x10 controller like this:
X10 Plug-In Desktop Mini Controller
   / I want to buy a new 425 this year but ... #25
Toys, toys, toys...:)
Sounds like a great setup. Those seem to be wonderful heaters. Thanks for the link.
All the best,
Peter
Object moved
   / I want to buy a new 425 this year but ... #26
Object moved
That heater looking lot like the one PT used.
   / I want to buy a new 425 this year but ... #27
Which heater?
   / I want to buy a new 425 this year but ... #29
Moss, your setup seems viable except for the last option. It is only rated for 120 volts
   / I want to buy a new 425 this year but ... #30
The controller only has to be 120 volts. It sends a signal over the power lines to the devices you want to control.
They make a 20A 110V outlet as well, just don't offer them on that website. I've had one running my pool pump for years.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
Nissan Forklift (A55973)
Nissan Forklift...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
HUSQVARNA RIDING MOWER 42INCH (A56859)
HUSQVARNA RIDING...
