Rear Blade I want one of these...
   / I want one of these... #2
I once came accross this at a used equipment dealer and still think about it. Building one that is. Actually got a spare grader blade for scrap price last summer just in case.
I wonder though. A real grader has enourmous weight, especially in the rear tandem wheel end. I wonder how stable a wheeled outfit like this would actually be.
   / I want one of these... #3
but I can't afford it.
Johnson Manufacturing | Home of the HyGrade Pull Type Graders
I have one of these...
RBT35 Series Rear Blades | Land Pride
Hard to use, (for me anyway)
Allen, you mention that the RBT3584 is difficult for you to use. :(
Do you have the skid shoes? These really help out IMO. :thumbsup:
Do you have draft control? Again this really can help out when properly setup.
Worse case, get the gauge wheel system for the unit as well as the skid shoes. Lots of :money: though. :eek:
These blades will move sideways if you load them too much when rolling dirt to the side. Even a full sized motor grader will do it. Like you, I am considering building my own but my problem is finding the blade. I actually have an old pull grader that is bent, beat up and worn out that I had thought of rebuilding but it only has a 6 foot blade. I want a 10 footer.
PS my 7 foot RGT3584 will shove my tractor sideways if I try to take to big a bite and I have loaded rears and 642 pound of cast weight on them too.
I do not have the gauge wheel or shoes. I priced the wheel this morning. It's a simple piece, very expensive so I'm going to build my own.
Draft? Not sure how draft control will help when the wheels fall in a hole and the blade takes a bite out of what I'm trying to grade. I understand draft for plowing but not in this instance. I don't have a problem overloading the tractor. I just dig holes when I don't want to. :D The gauge wheel will help a lot there. I should have gotten it when I bought the blade but I was trying to save $800.
   / I want one of these... #6
That rascal looks like a winner. I noticed that some of them have a large chunk of concerte just behind the blade. I wonder how you need to "balast" that thing to make it work.
Lookin at your 2 pics Allen, and living in Levelland, I'm wonderin' what your going to do with it!:laughing:
I recon some drainage & contour work. Looks like it takes some precision grading to get rid of water down there.:thumbsup:
I recon some drainage & contour work.:thumbsup:
"Levelland" Wonderin' what I'm going to do with it? Whatcher point? :D LOL
Well I plan to use it on a few roads and stuff that I try to maintain. When it rains we get lots of deep ruts in the dirt roads. Of course the county does the public roads but I want to get a bit of the private road business. I graded a few caliche roads this weekend and I pretty much made a mess. I was able to fix it but it took about double the time that it should have.
Yes, they have ballast boxes in the rear and the concrete block comes with it.
   / I want one of these... #8
That's a nice rear blade. Call me skeptical, but there's no way a 25hp CUT would be efficient while working that beast.
   / I want one of these... #9
Hey, if you are taking care of roads, you may want to include a LPGS if you don't already have one.
   / I want one of these... #10
I've tried for 26 years to maintain my mile long gravel driveway with a rear blade (Land Pride RB3596) in the summer. I finally gave up and bought a Land Pride GS2584. Makes all the difference in the world - I kick myself frequently for not making the change sooner.
2022 Adams CLC-1013 Conveyor - New (A55302)
2022 Adams...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
2013 TAKEUCHI TL10 SKID STEER (A52707)
2013 TAKEUCHI TL10...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
