I want a snowblower for my JD 2210
   / I want a snowblower for my JD 2210 #1
doug25427
Hedgesville, WV
JD 2210
I don't know much about front mounted snow blowers for a 2210. Let me start by telling you how my 2210 is laid out. It has a 210 FEL and a 54C mowing deck.
It seems to me the front mowing deck attachment is used for the blower mount. I assume the FEL hydro QD ports are used for the blower. Am I correct on these two points?
I assume a longer drive shaft is used from the mid PTO drive to extend to the front to drive the blower.
I understand the 54 and 47 inch blowers will work but the older 47 inch models seem to get a lot of praise.
My plan is to buy a used blower and hope to find the necessary attaching parts used if I can get so lucky.
As you can see I am lost on exactly how the blower attaches to the tractor. Without knowing exactly I can't find the right parts. Any help will be appreciated.
   / I want a snowblower for my JD 2210 #2
Ok so this is gong to take some research on your part. Google John Deere parts. What you want is their parts catalog. Enter your tractor in the search line and see what they list for attachments. Start googleing attachment kit part numbers. If you know the model of snowblower you are looking for then search that also on the Deere parts page. Quite often the attachment hitches are listed with the snowblower parts.
   / I want a snowblower for my JD 2210 #3
My JD hydraulic angle front blade uses a bracket that clearly is stamped with a hole for a front shaft, even has the 3 bolt holes to fasten a flanged bearing. Then I'm sure it would use a longer propeller shaft as stated above.
Someone on here has one, just can't remember who????
Thanks for the suggestions.
I figure someone here has done what I'd like to do. The best help I know of is a man who has been there and done that
   / I want a snowblower for my JD 2210 #10
That is the same kit used for the front blade like I have. Yep, good price.
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
