I Think I will Rebuild My Kubota
   / I Think I will Rebuild My Kubota
where did you find the clutch plate at that price. I was wondering because I think my clutch needs adjustment but I won't be hope to check it out for another week. I've been gone for 2 already. The dealer quoted about 5000$ but I think that probably includes the whole assembly and plates of the two stage clutch and 20 hours labour. But when I search online I noticed Bills tractors sells the clutch assembly for 2500$ . But then I see lots of other places advertising the clutch plates for similar prices to what you stated. Its a bit confusing when the prices seem to vary so much.
That seems like an awful lot of money. I know the dealers around here charge about $1200 to put a new clutch in a 2501 Kubota tractor. I actually thought that was highway robbery.
I bought my clutch at the Kubota dealership for around $150 I think. I bought other tractor stuff that day, so I will have to check the receipt.
I have yet to start this project because from July 3rd to Mid-September it is all out war on roadside mowing, so between teaching and mowing I have not even sat on the Kubota. (I mow with a John Deere 120 HP tractor with 18 foot boom mower)
   / I Think I will Rebuild My Kubota #12
Would the 1200$ be for parts and labour? The $5000 sounds a lot to me. But I didn稚 ask what that included either. He might have been quoting everything involved with a two stage clutch plus 20 hours labour. Also, I thought 20 hours seems long too. Maybe if I did it. But a dealer I thought could do it in 6 or 8 hours I would have thought. $1200 would be about $1600 here
   / I Think I will Rebuild My Kubota #13
Several years ago I had a B7200 that needed a throw out bearing, that old one was squealing real loud, The dealer quoted $1000 to tear it down and time and materials after that. I walked over to the parts counter and bought the bearing assy for around $25, went home and had it done that afternoon. It was a hydrostatic so very little clutch wear, the bearing had just seized up.
   / I Think I will Rebuild My Kubota #14
Jim, yes that seems more like it. And the comment you made about wear on the clutch being a hydrostat. I’ve been thinking of that too. Once engaged after initial start up and shift the tractor in gear, the clutch remains engaged pretty much until you get off the tractor or decide to put it back in neutral and shut it down. No engaging and disengaging to reverse the tractor or shifting gears. You’d figure the clutches have to last longer just due to less engagement or disengagement alone.
Jim, yes that seems more like it. And the comment you made about wear on the clutch being a hydrostat. I致e been thinking of that too. Once engaged after initial start up and shift the tractor in gear, the clutch remains engaged pretty much until you get off the tractor or decide to put it back in neutral and shut it down. No engaging and disengaging to reverse the tractor or shifting gears. You壇 figure the clutches have to last longer just due to less engagement or disengagement alone.
I like a manually geared tractor because a clutch is so cheap. My tractor has 3000 hours on it and needs a $150 clutch. That is a cost of 5 cents per operating hour.
Filters for a slosh drive will cost in excess of $150 over 3000 hours of use.
But it really depends on what you do with the tractor. I do a lot of field work, so a geared tractor makes more sense. A slosh drive would be nice when I work in my gravel pit granted, but it also robs the tractor of a lot of power.
The only perfect combination I found was my bulldozer with a hydraulic reverser with geared tranny. Now why don't all tractor have that?
   / I Think I will Rebuild My Kubota #16
Power shuttle. My hay guy has at least 5 bigger John Deere and they are old power shuttle. I think the first ones were called a reverser by Deere on their backhoes. I only have a 50hp and mine is a manual shuttle. But I still like it. Like you said the clutch is cheap and I do about 3 times as much field work compared to loader work.
I am around a lot of forestry equipment. But I work in office. A little timber land but my boss has a lot. A lot of pine trees in Alabama.
   / I Think I will Rebuild My Kubota #17
That makes one huge assumption! It assumes that the clutch pack was properly adjusted and little to no slippage ever occurred. While both are possible, it is also possible that neither happened!
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
2015 Nissan Versa (A55758)
2015 Nissan Versa...
2014 Ford Escape (A50324)
2014 Ford Escape...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A55787)
2017 Bomag BW90...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
