SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,514
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
You need to tighten the top bolts more after 1st checking that you have about an inch of thread engagement. There is absolutely no excuse for 15/16 dia bolts coming loose on a small tractor. The ones on my 7520 [a 12K# TL setup] are only 18mm - a little under 3/4". They never move and much of my work is heavy.I just went through re-torquing the bolts on my Stoll aftermarket loader...
My loader has 15/16 bolts with 4 on each side of the frame...
I usually check mine once a year at the beginning of mowing season and I always have the top bolts needing a little snugging...
For some reason the bottom ones stay tighter...
I do not do a lot of heavy work with my loader and do not abuse it in anyway but I can tell you for a fact that those bolts do work loose and need checking...
larry
