I Still Hate My Tractor II
   / I Still Hate My Tractor II #1
The Fred
hOOterville
Boost it and Lose!
So I have 50 hours blowing snow with it and now running an 8 inch Woodmax chipper. Before the turbo install the tractor engine would die out on anything over 5 inches of wood diameter. Now with the turbo you can't kill the engine, in fact Saturday I got a large piece of Maple stuck in the flywheel and the engine kept the Rs up and smoked the belts in no time, I love the new power.
Sunday morning I was checking the fluids and found engine oil in the radiator :blacksmith:
Back to the drawing board!
Fred
[video]http://s1373.photobucket.com/user/Frednation/media/IMGP0187_zps0ad89d01.mp4.html[/video]
   / I Still Hate My Tractor II #2
Sorry to hear this. It seems as it just could not take the boost. All of it, looks like great work, a fine machine and a real nice shop too!
Sometimes we just can't win, no matter how hard we try.
   / I Still Hate My Tractor II #3
So did you ever check the boost pressures? Obviously the head gasket let go.
No I didn't check the pressure but the wastegate was set at factory 7 psi. Also this oil is clean, does not look like the usual combustion gas garbage, and this design cylinder head has no oil passage going to the valvetrain through an oil galley. It uses the pushrods to move oil up to the valvetrain.
The intake pipe (pressure) side of the turbo stays cold during blowing and I can hold my hand on it no problem on the hottest , hardest day I used the chipper (60f degrees ambient). My guess is a crack in the block or faulty new oil cooler.
Open to suggestions, Fred
   / I Still Hate My Tractor II #5
I assume the oil cooler is inside the rad....if so, put the oil lines into a bucket of water, pressurize the rad and look for bubbles.
Also on a race car I had the oil pump and regulator went nutty and was pounding out too much pressure....I guess the weakest link was that oil cooler....this one was air.
Two things off the top of my head.
PS...I like the lights.
   / I Still Hate My Tractor II #6
7 psi isn't much, I'd look at the oil cooler first. Is the turbo water and oil cooled?
Turbo is a factory unit from a Bobcat S-160, V-2003t engine.
My oil cooler is from a VW 1.8 turbo, I bought new. My parts supplier sold 1100 of this part number oil cooler last year and had 110 returned defective; 1% defect rate. I can only hope the cooler leaked oil into the coolant.
Gotta find time, still cleaning up the yard from all the stone I blew onto the lawn :clover::greenthumb:ha ha.
Fred
   / I Still Hate My Tractor II #8
Sold 1100, returned 110?? I think that'd be around 10%!!
Nice work, BTW.
bumper
   / I Still Hate My Tractor II #9
Fred
Well if it isn't the head gasket is it possible that it has pushed oil through a seal in the turbo and into the coolant line?? Isn't the oil cooler completely separate??
   / I Still Hate My Tractor II #10
Do you know the wastegate is working properly. 7 psi will not hurt anything so something went haywire. I know those turbos will boost well over 20 psi if allowed to.
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
1974 John Deere 6030 Tractor (A56435)
1974 John Deere...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
1985 Allmand Max Lite III LD30-3CE S/A Towable Light Tower (A55973)
1985 Allmand Max...
Ford 8340 (A53317)
Ford 8340 (A53317)
Dump Hopper, 43" W x 39" D (A59076)
Dump Hopper, 43" W...
