I Screwed Up
   / I Screwed Up #1
mjarrels
Elite Member
Virginia
1949 farmall, 1961 Fordson Dexta, 1986 Duetz Allis, 2001 Kubota.
I usually move all my paint, stains and water sealers into the basement from the garage each fall to keep from freezing. Forgot last year, was reading the label on a unopened can of water sealing that said "do not freeze - not effective if previously frozen" It was very cold for a few weeks... jug of summer windshield washer froze solid in garage. Is there some way to tell if these products also froze? Really hate to toss full cans.
mark
   / I Screwed Up #2
Afternoon Mark,
I dont know about the windshield washer fluid, but I have left some of my oil based stains in the garage during the winter and they seemed to be fine in the spring !
The bottom line is I have done the same thing , you just forget, and about this time of year you walk out in the garage, look at the shelf and shake your head ! ;)
   / I Screwed Up #3
I would like to think if the cans didnt bust open,it all should be fine,but ive been wrong before.
ALAN
   / I Screwed Up #4
Try the paint. If it dries, I would go ahead and use it.
I do the same thing with my paint etc - wood glue from my exoerience is sensitive to frost.
   / I Screwed Up #5
It should be fine. I've had some freese and it still worked fine. It did seem to have more trash in it than normal. Just strain it much more than normal if you are using it in a sprayer.
James
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED DIGGIT 6'5"-16 DRAWER, 4 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
