I ran over this....what is it?
   / I ran over this....what is it? #11
Various lengths of this are used as a line-up tool to align steel girders for bolts, larger pipe flange holes for bolts, etc. Very handy, but not the way that I'd want to acquire one . . .
I use something similar to tweak heavier 3-point implements if I'm having trouble lining them up. Lots of leverage.
   / I ran over this....what is it? #12
I've had a similar in my tool box for years, Labeled Craftsman USA 42882. Just a handy pin/pry bar.
That is a good idea. Might keep it on the tractor instead.
   / I ran over this....what is it? #14
You're probably fortunate it didn't end up in your tire. I've been driving a lot of years, and have found all sorts of things in my tires...including a T-bone, from a T-bone steak (no, it wasn't mine; could barely afford bologna).
   / I ran over this....what is it? #15
My worst tire enemy is deer antler sheds
I pulled a pair of pliers out of a tire once. One of the handles went right in.
The biggest problem I have on my property is locust trees. Somehow my tractor has been unscathed but have had several flats on my truck. Was able to plug them though.
   / I ran over this....what is it? #17
I call that tool a dibble. Very handy tool. I have a dibble made by Crescent. Crescent head on the top end - long dibble for the handle. I use mine for final match up when hooking up 3-point implements.
Used mine today to line up the 3 point hitch. Great tip guys.
   / I ran over this....what is it? #20
Particularly handy for me. With my M6040 I've slowly but surely converted over to all Cat 2 implements. You DO NOT give a Cat 2 rear blade a side thrust with your hip to move it a bit. But the Kubota has extendable 3-point arm ends and all my implements are stored on pallets.
Sooo...... with my uber heavy pry bar - extendable 3-point ends and the dibble - - I don't need as many four letter words to connect up a 3-point implement.
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
3pt 2 Row Plow (A53317)
3pt 2 Row Plow...
1995 CATERPILLAR 928F WHEEL LOADER (A52707)
1995 CATERPILLAR...
JMR Attachments Quick Attach Tree Boom (A56469)
JMR Attachments...
2011 Ford Escape SUV (A55853)
2011 Ford Escape...
2016 VOLVO L45H WHEEL LOADER (A52707)
2016 VOLVO L45H...
