I put gas in the hydraulic tank
   / I put gas in the hydraulic tank #1
Bonzoretro
2015 Dig It M2208
What do you do next if gas was put in the hydraulic tank? Engine was not started at all.
Dig-It M2208 bucket loader.
   / I put gas in the hydraulic tank #2
Hydraulic or diesel tank?
   / I put gas in the hydraulic tank #5
Do not start or operate! follow post # 3
   / I put gas in the hydraulic tank #7
Drain, but flush out remaining gas with clean oil first. A couple of quarts so you don't contaminate the final oil fill. Small price to pay...
   / I put gas in the hydraulic tank #8
Drain the tank and flush with clean oil then refill with the proper oil. Definitely don’t start it or the gas is going to mix with the entire system.
   / I put gas in the hydraulic tank #9
how much gas poured into hyd sump? of course follow above advice. & yes, flush before final fill...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
2013 Ford F-450 Dump Truck (A55852)
2013 Ford F-450...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
