I "possibly" have a problem with my diesel truck
   / I "possibly" have a problem with my diesel truck
Re: I \"possibly\" have a problem with my diesel truck
Okay, I have never messed with a 4x4 but if you have enough floor jacks how bad could it be?? At least with a 4x4 you can do most of the work without jacking the truck itself up. With my Vette I had the car up as far as was safe on my stands and I still had to remove the bell housing while under the car to get the trans out.
Jeff
I got it fixed!!!! /forums/images/graemlins/laugh.gif
First I filled the system with distilled water to clean out the flush letting each gallon drain out of the overflow before I added the next........same problem.
I then took the sensor out to check if it was actually changing resistance by first sticking it in ice and then boiling water. It was but since I don't have a manual I was unsure if it had the right resistance values or not. Two funny things were that I was never able to get it to show no connection and when I put it in boiling water bubbles came out from around the insulator.
Then I added the coolant so slow that there was never any in the tank....basically dribbled it in.....same problem. Let it cool once more and took it out for a ride. This time the Engine Temp light came on before I hit the entrance to the sub while the other guage still read cold. Now I was convinced it's the sensor.
Called every auto parts in the area and either they didn't carry it or it would take 3 weeks to get one. Finally called Ford and yes they had one.......For $55.00!!!!! Had no choice so today I picked one up and Viola....problem solved!!! Funny thing was that when I showed up at Ford they gave me the dealer discount and the total was under $25.00. Maybe I looked as though I needed some pity. He said that $55.00 was their matrix price whatever that is.
Anyways, vacation on!!!!
Thanks for the help!!!! /forums/images/graemlins/smile.gif
Jeff
P.S. Is it okay to use superglue on cuts deep enough to require stitches......I sure hope so! /forums/images/graemlins/crazy.gif
LOT OF REDBAND FENCE WIRE (A58374)
LOT OF REDBAND...
(INOP) KUBOTA L3000 MFWD TRACTOR (A52708)
(INOP) KUBOTA...
2019 Ford Transit 250 Cargo Van (A56858)
2019 Ford Transit...
2008 CAT D6T DOZER (A58216)
2008 CAT D6T DOZER...
PALLET OF MIXED METAL, FLAT & ROUND STOCK, ANGLE (A52708)
PALLET OF MIXED...
PALLET OF ROUND STOCK & PIPE (A52708)
PALLET OF ROUND...
