I/P Cameras on the Farm. The Good Bad and The Ugly
   / I/P Cameras on the Farm. The Good Bad and The Ugly #11
First thing to do is unplug the camera and take it into your house. You never work on that sort of thing with the camera hundreds of feet away and with all that other hardware between your computer and the camera. Get it working at your desk, first, and then take it out and put it in its final location.
The readers digest version of what is required to make it work is your computer and the camera must be on the same IP network. So if your desktop computer has an IP of say 192.168.1.2 then the camera will have to have an IP somewhere in the range of roughly 192.168.1.3 - 192.168.1.253.
So if your computer is 192.168.1.2 and the camera is 192.168.1.3 they will be able to talk to each other and the camera should work. Your router is likely set up with DHCP which means it will assign the IP addresses to devices on your network. Your router also likely does Network Address Translation (NAT) which will give you a public (internet) IP address. NAT allows the public IP address and the internal addresses in the 192.168.1.x range to talk to each other and therefore those devices can access the internet and vice versa. There is also something called port forwarding in your router, which may eventually need to be set up for the camera so that you can access the camera from the Internet. But don't worry about port forwarding to start with. See if you can get your desktop to talk to the camera first just using your local internal (192.168.1.x) network.
Find the install manual for the camera and it should walk you through setting the camera up to work with your network. If you bring the camera in the house as I suggested, you'll have a lot more luck. It shouldn't be that complicated to set up. Normally it only takes 15 minutes.
Oh, and if you do set it up so that you can access the camera from the internet or using your phone when you're out and about, just keep in mind that people will be using that camera to watch you. None of those cameras are secure and you can count on people watching you. The only way to avoid that is to set up a VPN (virtual private network) that is required to access the camera.
   / I/P Cameras on the Farm. The Good Bad and The Ugly #12
You might find my thread on the Reolink IP cameras interesting. I had to have the cameras plugged into the network for setup.
   / I/P Cameras on the Farm. The Good Bad and The Ugly #15
Even though you think the switches are transparent the camera might be on a different subnet from your PC. If so you will never connect to it.
You can try to ping the camera, which is easy to do. If you can't ping it, you can't connect to it. Here is how:
1. Determine the camera IP address. The default should be shown in the manual.
2. On a Windows PC, open a MS-DOS window. You might need to navigate to >Start>Accessories to find that command prompt.
3. At the C> prompt, type ping and then IP address. What you type will then look like: C>ping 192.168.1.100
4. Watch the responses. If you see "Reply from ...." then you can connect to it. If you see anything else, you can't.
You can try this without moving the camera. But if you don't get a reply I would move the camera to the house for testing next.
And remember the three rules for wireless video!
The camera is an Engenius EDS5110. Not great but it was free and I "Thought" it would be good to cut my teeth on this IP camera stuff. It has a POE injector which I will use to provide power up the tower.
YES, I should have had the camera on the desk. Naive of me! I thought this would be easy. The ISP installer said that he could set it up. But my old XP box didn't have the right plug in and I had no apple account for my phone.
I need to read all the response, but have a little emergency to deal with. Thanks.
   / I/P Cameras on the Farm. The Good Bad and The Ugly #17
Injector needs to be at the final run to the camera
Network.........Poe injector.........camera.
Poe injector will require a power source.
   / I/P Cameras on the Farm. The Good Bad and The Ugly #19
They all work about the same, basic networking.
I give mine static ip on my local network.
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
